show system_state
Use the show system_state command to display the Wireless Appliance's system information.
show system_state process | cpu | memory | disk | mgmt | uptime | info | manufacturing
Parameters
process Displays the current CPU and memory usage of system processes.
cpu Displays the amount of CPU usage.
memory Displays the amount of memory being used on the system.
disk Displays the hard-disk usage by folder.
mgmt Displays the system management settings.
uptime Displays the amount of time the system has been running continuously.
info Displays the information on various processes run by the system.
manufacturing Displays hardware information about the controller.
The following example displays the current processes running on the system:
EWC.extremenetworks.com# show system_state process
PID      Process Name             State       % CPU    % Mem
1123     VN Manager               S           0.0      0.9
8010     NSM Server               S           0.0      0.6
16527    Config Manager           S           0.0      1.6
1425     CLI                      S           0.0      3.5
-        OSPF Server              inactive    -        -
-        Remote INS               inactive    -        -
15891    Langley                  S           0.0      0.5
1111     RU Manager               S           0.0      0.9
15893    SNMP Agent               S           0.0      0.5
-        RF Data Collector        inactive    -        -
23758    Radius Client            S           0.0      0.5
960      Stats Server             S           0.0      0.6
16566    Security Manager         S           0.0      0.9
656      Event Server             S           0.0      1.4
548      Startup Manager          S           0.0      0.5
1131     RU Session Manager       S           0.0      0.5
974      Host Services Manager    S           0.0      2.3
1117     Radius Accounting        S           0.0      0.4
-        DHCP                     inactive    -        -
990      Test Client              S           0.0      0.4
1129     LLC Handler              S           0.0      0.6
The following example displays the CPU usage on the system:
EWC.extremenetworks.com# show system_state cpu
CPU states:  1.5% user,  1.5% system,  0.0% nice,  6.8% idle
The following example displays the memory usage on the system:
EWC.extremenetworks.com# show system_state memory
Mem:   247372K av,  235516K used,   11856K free,       0K shrd,   67528K buff
Swap: 1028120K av,    6368K used, 1021752K free                   85756K cached
The following example displays the hard disk usage (C25 platform):
EWC.extremenetworks.com# show system_state disk
Partition    Total Space    Used      Available    Use %
root         27193624       381960    25992592     2%
home         2040016        32840     1986696      2%
cdr          2032048        32812     1978756      2%
logs         1528032        33180     1479512      3%
reports      1522032        32812     1473880      3%
trace        1531008        32812     1482856      3%
tmp          131072         32        131040       1%
The following example displays the system management settings:
EWC.extremenetworks.com# show system_state mgmt
Software version: 9.xx
Software build: 09.xx.0x.0xxx
Product Name: C25
Hostname: EWC
Domain: extremenetworks.com
IP Address: 192.168.33.333
Subnet Mask: 255.255.255.0
Mgmt Gateway: 192.168.22.2
Static IPv6 Address: fd66:2280:2669:ffff::102 64
Static IPv6 Gateway: fd66:2280:2669:ffff::105
Dynamic IPv6 Address:
1: fd66:2280:2669:ffff:021b:21ff:feb0:899a 64
2: fd66:2280:2669:0000:021b:21ff:feb0:899a 64
3: fe80:0000:0000:0000:021b:21ff:feb0:899a 64
4: fe80:0000:0000:0000:0230:48ff:fe77:a94a (gw)
Primary DNS: fd66:2280:2669::f
Secondary DNS: 192.168.33.332
Time Zone: America/Montreal
Country: CA
The following example displays system uptime:
EWC.extremenetworks.com# show system_state uptime
System uptime: 6 days, 1:49
