Use the ospf-advert command to enable or disable OSPF advertisements on the topology. The ospf-advert command is available from the topology:<named-topology>:l3 context of the CLI for routed topologies.
After you run the ospf-advert command, run the apply command to implement the changes.
| enable | Enables OSPF advertisements. |
| disable | Disables OSPF advertisements. |
The following example enables OSPF advertisements:
EWC.extremenetworks.com:topology:r1:l3:# ospf-advert enable
Print
this page
Email this topic
Feedback
