Use the extredir command, within context wlan:<WLAN-service-name>:auth:captiveportal, to specify the External Redirection URL.
After you run the extredir command, run the apply command to implement the changes.
| value_string | Specifies a URL beginning with http:// |
| none | Specifies that no external redirection URL is configured |
The external authentication mode must be set for this command to be available. For more information, see mode.
The following example specifies an External Redirection URL:
EWC.extremenetworks.com:wlans:CNL-7-CP:auth:captiveportal# extredir http://192.168.4.89:80 EWC.extremenetworks.com:wlans:CNL-7-CP:auth:captiveportal# apply
Print
this page
Email this topic
Feedback
