Use the svcmsg command to enable DHCP messages. Use the no form of the command to disable these and use log and traces messages only.
None
The following example enables service messages on the system:
EWC.extremenetworks.com:syslog# svcmsg Successfully turned on service messages.
The following example disables service messages:
EWC.extremenetworks.com:syslog# no svcmsg Successfully turned off service messages.
Print
this page
Email this topic
Feedback
