Use the cp-http command to enable HTTP support for a WLANs service captive portal context.
| enable | Enables HTTP support for the current context |
| disable | Disables HTTP support for the current context |
The internal or splash authentication mode must be set for this command to be available. For more authentication mode information, see mode.
The following example enables HTTP support for the Lab126-12-GuestSpl WLAN service:
EWC.extremenetworks.com:wlans:Lab126-12-GuestSpl:auth:captiveportal# cp-http enable
Print
this page
Email this topic
Feedback
