Use the radio1-strictlimit command to enable or disable strict enforcement of hard load limits on Radio1 when Radio Load Control is active. When strict limit is enabled, any clients in excess of the configured limits on the radio are immediately disconnected. The radio1-strictlimit command is accessible from the ap:load-groups:<named-loadgroup> context.
| enable | disable | Enables or disables the strict enforcement of load limits on Radio1. |
Radio Load Control must be enabled for this radio before this command can take effect.
The following example enables strict load limiting on Radio1:
EWC.extremenetworks.com:ap:load-groups:radiogroup1# radio1-strictlimit enable
Print
this page
Email this topic
Feedback
