Use the show tech_support command to display a list of technical support files available on the system.
Use tech_support to generate technical support files. For more information, see tech_support.
None
The following example displays the available technical support files:
EWC.extremenetworks.com# show tech_support 1: tech-ac.tar.gz 2: tech-all.tar.gz 3: tech-ap.tar.gz 4: tech-log.tar.gz
Print
                        this page
Email this topic
Feedback
