Use the atpc command to enable Auto Tx Power Ctrl (ATPC). Use the no form of the command to disable the ATPC feature. The atpc command is accessible from all radio1 and radio2 contexts of the CLI.
After you run the atpc command, run the apply command to implement the change.
| maintain_power | When you disable ATPC, you can elect to maintain using the current Tx power setting ATPC had established. |
The following example disables atpc on Radio 1:
EWC.extremenetworks.com:ap:defaults:ap3801:radio1# no atpc maintain_power
Print
                        this page
Email this topic
Feedback
