Use the delete command to remove a filter rule from the filter list. The delete command is accessible from within the vnsmode:<default-role>:acfilters and vnsmode:<default-role>:apfilters contexts.
| pos | Specifies the filter rule list position of the filter to be deleted. Valid values are 0 - 255. |
The following example deletes filter rule 1 and displays the remaining default deny all rule:
EWC.extremenetworks.com:vnsmode:p1:acfilters# delete 1 EWC.extremenetworks.com:vnsmode:p1:acfilters# show Enable AP filtering: disable filter 1 (default) proto none 0.0.0.0 all_ports both deny
Print
this page
Email this topic
Feedback
