hs-rc
Use the hs-rc command from the hotspot context to configure the roaming consortium for the hotspot. Configure authentication of mobile devices to the members of a roaming consortium, or to a particular SP that has a roaming consortium.
hs-rc (add|delete) rc
Parameters
(add|delete) rc Add or delete a roaming consortium value.
Usage
The rc can be a 6 or 10-digit hexadecimal number.
EWC.extremenetworks.com:wlans:hs:hotspot# hs-rc AA2211
