Use the name command to modify the name of this WLAN service. The name command is accessible from the wlan:<WLAN-service-name> context of the CLI when the WLAN service type is STD.
After you run the name command, run the apply command to implement the name change.
| WLAN-service-name | Specifies the name to use for this WLAN service |
The following example changes the name of the test WLAN serve to “not-test”:
EWC.extremenetworks.com:wlans:test# name not-test EWC.extremenetworks.com:wlans:test# apply EWC.extremenetworks.com:wlans:test# show name Name: not-test
Print
this page
Email this topic
Feedback
