Use the trap-manager-v3 command to identify either the primary or secondary machine monitoring SNMPv3 traps by IP address.
| 1|2 | Identifies the primary or secondary machine monitoring SNMPv3 traps |
| IP address | Specifies the IP address of the machine monitoring SNMPv3 traps. The IP address can be either IPv4 (A.B.C.D) or IPv6 (A:B:C:D:E:F:G:H) format. |
| delete | Removes the SNMPv3 machine monitoring SNMPv3 traps |
The following example specifies the IP address of the primary machine monitoring SNMPv3 traps and the SNMPv3 user “admin”:
EWC.extremenetworks.com:snmp# trap-manager-v3 1 192.168.1.5
The following example deletes the primary trap manager configured in the previous example:
EWC.extremenetworks.com:snmp# trap-manager-v3 1 delete
Print
this page
Email this topic
Feedback
