Use the name command to change the name of a load group.The name command is accessible from the ap:load-groups:<named-load-group> context of the CLI, for both types of load groups.
| load group name | The new name of the load group. |
After you change the name of the load group and apply the change (with the apply command), the ap:load-groups:<named-load-group> context retains the previous name of the load group. To change the ap:load-groups:<named-load-group> context to the new name of the load group, you exit the context and then enter the ap:load-groups:<named-load-group> context using the new name.
The following example changes the name of loadgroup1 to lg_lab:
EWC.extremenetworks.com:ap:load-groups:loadgroup1# name lg_lab EWC.extremenetworks.com:load-groups:loadgroup1# apply EWC.extremenetworks.com:load-groups:loadgroup1# exit EWC.extremenetworks.com:load-groups# ? Available commands are: create Create load group delete Delete load group end Return to the base mode exit Return to the previous mode if not in the base mode lg_lab Configure details for load group lg_lab logout Exit the shell show EWC.extremenetworks.com:ap:load-groups# lg_lab EWC.extremenetworks.com:load-groups:lg_lab#
Print
this page
Email this topic
Feedback
