hotspot
A hotspot-enabled WLANS is under the wlans context. The context for the following hotspot commands is as follows: root > wlans > <hotspot enabled wlan> > hotspot. Use these commands to configure the hotspot-enabled WLANS.
EWC.extremenetworks.com:wlans:hs-wlan# hotspot
