Use the delete command to delete the TCPDump file. The delete command is accessible from the traffic_capture context of the CLI.
To display the “TCPDump file capture” list, run the list command from the traffic_capture context of the CLI. For more information, see list.
| # from the capture file list | The sequence in which the files are listed in the capture file list |
The following example specifies the file # 1 in the “TCPDump file capture” list to be deleted:
EWC.extremenetworks.com:traffic_capture# delete 1
Print
this page
Email this topic
Feedback
