Use the hs-3gpp command from the hotspot context to configure the 3GPP Cellular Network for the hotspot.
| add|delete | Specifies to add or remove 3GPP Cellular Network for the hotspot. |
| mcc mnc | Cellular network IDs in the form of mobile country code, mobile network code (MCC, MNC). |
The MNC and MCC must be a 3-digit, positive number.
EWC.extremenetworks.com:wlans:hs:hotspot# hs-3gpp add 333 111
EWC.extremenetworks.com:wlans:hs:hotspot# hs-3gpp delete 333 111
Print
this page
Email this topic
Feedback
