schld_upgrd
Use the schld_upgrd command to schedule a local or remote upgrade of the Wireless Appliance‘s software. Use the no form of the command to delete the scheduled upgrade. This command is accessible from the schedule_upgrade context.
Before you schedule a local uprade, download the upgrade image to the controller.
[no] schld_upgrd MM:DD:hh:mm (local image_name) |(remote server user password dir image_name)
Parameters
MM Month on which the upgrade will be carried out
DD The date on which the upgrade will be carried out
hh:mm The time (in 24-hour format) at which the upgrade will be carried out
local Specifies that the new software will be downloaded locally from the Wireless Appliance
image name The new software‘s file name
remote Specifies that the new software will be downloaded from the remote FTP server
server The remote FTP server where the image file is located
user The user name to access the FTP server
password The password to access the FTP server
dir The path to the directory where the new software is stored on the FTP server
If you want to delete the existing local upgrade schedule, add no before the local upgrade syntax as shown in the following example:
EWC.extremenetworks.com:schedule_upgrade# no schld_upgrd
The following example schedules a local upgrade:
EWC.extremenetworks.com:schedule_upgrade# schld_upgrd 06:01:12:00 local AC-MV-07.41.03.0003-1.rue
The following example schedules a remote upgrade:
EWC.extremenetworks.com:schedule_upgrade# schld_upgrd 06:01:12:00 remote 192.168.4.10 test abc123 /ac/rpm/build07.41.03.0003 AC-MV-07.41.03.0003-1.rue
If you want to delete the existing remote upgrade schedule, add no before the remote upgrade syntax as shown in the following example:
EWC.extremenetworks.com: schedule_upgrade# no schld_upgrd
