This section describes commands used to create and manage user accounts on the network. These commands are found within the users context of the CLI.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
The following commands are available in the users context:
Print
                        this page
Email this topic
Feedback
