Use the replay_interval command to configure the DAS replay interval, measured in seconds. The replay_interval command is available from the vnsmode:das context.
| 0-1000 | Specifies the DAS replay interval, measured in seconds. |
The following example sets the DAS replay interval to 60 seconds:
EWC.extremenetworks.com:vnsmode:das# replay_interval 60
Print
this page
Email this topic
Feedback
