Use the n_pbthreshold command to specify the extension channel threshold. This value is used to determine which channel width to use when the n_chlwidth is set to auto.
| 0-100 | Specifies the extension channel threshold value as a percentage. |
This command is not available for AP38xx radio 1 and AP39xx both radios.
The following example sets the extension channel threshold value to 60 per cent:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio2# n_pbthreshold 60
Print
                        this page
Email this topic
Feedback
