The radius-timeout-policy command within context wlan:<WLAN-service-name>:auth sets the specified policy from the list of configured policies to apply when the authentication request to the RADIUS server times out. By default, the treat-like-access-reject policy is applied when authentication requests time out.
After you run the protocol command, run the apply command to implement the changes.
| policy name | Specifies the name of the policy to apply when an authentication request times out. |
| treat-like-access-reject | Specifies that the authentication request be treated as an authentication failure when the authentication request times out. This is the default. |
The following configurations must already be in place before this command is available:
See role_commands for creating and naming policies.
The following example selects the p6 policy to apply when authentication queries to this RADIUS server time out:
EWC.extremenetworks.com:wlans:new-wlans:auth# radius-timeout-policy p6
Print
this page
Email this topic
Feedback
