Use the create command to create a bandwidth rate control profile with an average rate in kbps. You can create up to 128 profiles. The create command is accessible from the vnsmode:rateprofile context of the CLI.
In the vnsmode:rateprofile context, use the command to delete a bandwidth rate control profile, and use the show command to display existing rate control profiles.
After you run the create command, run the apply command to implement the changes.
| profile_name | Specifies the name of the rate control profile. If you are using a profile name that consists of two words and the two words are separated by space, you must put the profile name in double quotes (“). |
| average rate | Specifies committed information rate (CIR) in Kbps. Average Rate (CIR) must be between 128 and 200000 (kbps). |
The following example creates a bandwidth rate control profile named lowspeed with 200 Kbps of CIR:
EWC.extremenetworks.com:vnsmode:rateprofile# create lowspeed 200
The following example creates a bandwidth rate control profile named high speed with 700 Kbps of CIR:
EWC.extremenetworks.com:vnsmode:rateprofile# create “high speed” 700
Print
this page
Email this topic
Feedback
