Use the loglevel command to set the log level for the Wireless Appliance or the Wireless APs. The optional stationlog, send2wm, and send_station_trap parameters support station session streaming logs.
| ac | Sets the log level of the Wireless Appliance. |
| ap | Sets the log level of the Wireless APs. |
| 1 | Indicates Critical severity level. |
| 2 | Indicates Major severity level. |
| 3 | Indicates Minor severity level. |
| 4 | Indicates Informational severity level. |
| stationlog | Enables or disables station session event reporting on the controller station events log. |
| send_station_trap | Enables or disables station event forwarding as SNMP traps. |
| send2wm | Enables or disables sending station session events to the Wireless Manager. |
The following example sets the Wireless Appliance's log level to Minor:
EWC.extremenetworks.com# loglevel ac 3 Successfully set ac log level to Minor (3)
The following example sets the Wireless Appliance log level to Information and enables station event reporting on the the controller station log, but doesn‘t enable station event forwarding to Wireless Manager:
EWC.extremenetworks.com# loglevel ac 4 stationlog enable send2wm disable
The following example sets the AP‘s log level to Information:
EWC.extremenetworks.com# loglevel ap 4
