Use the priority-override-dscp command to override existing DSCP codepoint assignments for priority processing and use a single DSCP codepoint for the WLANS. The priority-override-dscp command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the priority-override-dscp command, run the apply command to implement the changes.
| 0-64 | Specifies a DSCP codepoint value. Default value: 0. |
This command is only active if the priority-override command has been enabled. For more information, see priority-override.
The following example overrides all existing DSCP codepoint assignments and uses DSCP codepoint 2 for the CNL-7-CP WLANS:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# priority-override-dscp 2 EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# show priority-override-dscp DSCP marking: 2
Print
                        this page
Email this topic
Feedback
