Use the redirect command, within context wlan:<WLAN-service-name>:auth:captiveportal, to specify the Default Redirection URL.
After you run the redirect command, run the apply command to implement the changes.
| value_string | Specifies a URL beginning with http:// |
| none | Specifies that no Default Redirection URL is configured |
The guestportal, internal or splash authentication mode must be set for this command to be available. For more information, see mode.
The following example specifies the internal network URL to which to redirect connecting users:
EWC.extremenetworks.com:vnsmode:CNL-7-CP:auth:captiveportal# redirect http://192.168.1.38 EWC.extremenetworks.com:vnsmode:CNL-7-CP:auth:captiveportal# apply
Print
this page
Email this topic
Feedback
