Use the dosa command to enable or disable removal of network access from clients originating DoS attacks. The dosa command is accessible from the mitigator:scprof:<named scan profile> context and the mitigator:gsprof:<named guardian scan profile> context of the CLI.
After you run the dosa command, run the apply command to implement the change.
| enable | Enables removal of clients originating DoS attacks from network access |
| disable | Disables removal of clients originating DoS attacks from network access |
The following example enables DoS attack client removal:
EWC.extremenetworks.com:mitigator:scprof:scp_name# dosa enable EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
Print
                        this page
Email this topic
Feedback
