Use the legacy command to enable or disable the legacy solution, which gives all packets on the VNS high priority. The legacy command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the legacy command, run the apply command to implement the changes.
| enable | disable | Enables or disables the legacy solution. |
Legacy Wireless QoS support cannot be re-enabled once it has been disabled.The following example enables the legacy solution for the VNS:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# legacy enable EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# show legacy Legacy: enable
Print
this page
Email this topic
Feedback
