Use the location-engine command to enable or disable the RF Location engine on this controller.
The location-engine command is accessible from the location context of the CLI.
| enable | disable | Enables or disables the location engine on this controller. |
The following example enables the RF location engine:
EWC.extremenetworks.com:location# location-engine enable
Print
this page
Email this topic
Feedback
