Use the wpa-broadcast-rekey command to configure the re-key interval for group keys. The wpa-broadcast-rekey command is accessible from the wlan:<WLAN-service-name>:priv context of the CLI.
After you run the wpa-broadcast-rekey command, run the apply command to implement the name change.
| none | Disables the re-key interval for group keys |
| 30-86400 | Specifies the re-key interval for group keys in seconds |
The wpa-broadcast-rekey command is available when the privacy mode is set to wpa or wpa-psk. For more information, see mode.
The following example sets the WPA re-key interval to 300 seconds:
EWC.extremenetworks.com:wlans:test:priv# wpa-broadcast-rekey 300 EWC.extremenetworks.com:wlans:test:priv# apply EWC.extremenetworks.com:wlans:test:priv# show wpa-broadcast-rekey Broadcast re-key interval (seconds): 300
Print
this page
Email this topic
Feedback
