Use the show log command to display logs and reports for the Wireless Appliance.
| log_name | The log that you want to view:
| first | Indicates that the first records in the log will be displayed. |
| last | Indicates that the last records in the log will be displayed. |
| number | Specifies the number of logs to display from the file. |
EWC.extremenetworks.com# show log auditRecords.log first 2 5516324453019803260admin CLI_controller general key configuration changed: activate TRDKNAM-NCF47ABS-I1BVRP9U-SGDKVBFR-NFBQ6ZJQ, 5516324457314024504admin CLI_system_management general downloading import file from server 192.168.3.108
EWC.extremenetworks.com# show log dhcp last 5 Timestamp DHCP Message Sep 13 20:33:14 dhcpd: DHCPACK to 172.21.177.21 (00:11:95:ec:a7:c0) via esa9 Sep 13 20:34:53 dhcpd: DHCPINFORM from 172.21.177.21 via esa9 Sep 13 20:34:53 dhcpd: DHCPACK to 172.21.177.21 (00:11:95:ec:a7:c0) via esa9 Sep 13 20:34:56 dhcpd: DHCPINFORM from 172.21.177.21 via esa9 Sep 13 20:34:56 dhcpd: DHCPACK to 172.21.177.21 (00:11:95:ec:a7:c0) via esa9
EWC.extremenetworks.com# show log ospf-neighbor Neighbor RouterID Router Priority State IP Interface 192.168.12.7 1 Full/DR 10.91.0.2 esa0:10.91.0.1
EWC.extremenetworks.com# show log ospf-linkstate Router LSA (Type 1): Link ID Advertising Router Age Sequence No Checksum Link Count 192.168.4.202 192.168.4.202 1460 0x80000085 0x8f18 3
EWC.extremenetworks.com# show log upgradeLog.txt OS-7_31_0-7 Wed Mar 19 14:21:48 EDT 2008 OS-5_1_8-1 Installing rpm of version V5R1.10034.0 on Wed Mar 19 14:21:53 EDT 2008 Tue Mar 10 12:39:04 EDT 2009 OS-5_3_17-1 Installing rpm of version V5R3.10034.0 on Tue Mar 10 12:39:11 EDT 2009 Mon Jun 1 10:52:53 EDT 2009 OS-6_0_19-1 Installing rpm of version V6R0.10019.0 on Mon Jun 1 10:52:59 EDT 2009 Thu Aug 20 14:47:27 EDT 2009 OS-6_1_8-1 Installing rpm of version V6R1.10029.0 on Thu Aug 20 14:47:39 EDT 2009 Installing rpm of version V6R1.10602.0 on Mon Sep 13 05:11:30 EDT 2010 Installing rpm of version 07.41.01.0122T on Mon Sep 13 05:31:02 EDT 2010 EWC.extremenetworks.com#
EWC.extremenetworks.com# show log upgrade.log Sep 13 05:30:47 EDT 2010 From: V6R1.10602.0 To: 07.41.01.0122T Sep 13 05:30:47 EDT 2010 C25 Upgrading From Release 6_1 Sep 13 05:35:05 EDT 2010 Successfully imported license Sep 13 05:35:21 EDT 2010 Successfully Restored the Configuration Sep 13 05:35:22 EDT 2010 Successfully Performed Netsight Import EWC.extremenetworks.com#
EWC.extremenetworks.com# show log configChanges.log CLI Import/EWC.extremenetworks.com: start: Tue Sep 14 00:27:57 2010 CLI Import/EWC.extremenetworks.com: end: Tue Sep 14 00:28:16 2010 EWC.extremenetworks.com#
EWC.extremenetworks.com# show log station Msg: 06/14/13 06:58:34 EventType[De-registration] MAC[00:24:D7:23:89:4C] BSSID[00:0F:BB:09:EC:E9] Details: VNS[CNL-91-0-6] Cause[Idle timeout] Msg: 06/14/13 05:49:48 EventType[State Change] MAC[00:24:D7:23:89:4C] IP[172.21.176.54] BSSID[00:0F:BB:09:EC:E9] SSID[CNL-91-0-6-ssid] User[tester1] Msg: 06/14/13 05:49:45 EventType[Authentication] MAC[00:24:D7:23:89:4C] AP[0500006072051204] BSSID[00:0F:BB:09:EC:E9] SSID[CNL-91-0-6-ssid]User[tester1] Details: VNS[CNL-91-0-6] AppliedRole[CNL-91-0-6-default] Msg: 06/14/13 05:49:45 EventType[State Change] MAC[00:24:D7:23:89:4C] BSSID[00:0F:BB:09:EC:E9] Details: VNS[CNL-91-0-6] Auth[valid] Msg: 06/14/13 05:49:44 EventType[State Change] MAC[00:24:D7:23:89:4C] BSSID[00:0F:BB:09:EC:E9] Details: VNS[CNL-91-0-6] Auth[invalid] Msg: 06/14/13 05:49:44 EventType[MBA Accepted] MAC[00:24:D7:23:89:4C] AP[0500006072051204] BSSID[00:0F:BB:09:EC:E9] SSID[CNL-91-0-6-ssid] Details: VNS[CNL-91-0-6] AppliedRole[CNL-91-0-6-default] Msg: 06/14/13 05:49:44 EventType[Registration] MAC[00:24:D7:23:89:4C] AP[0500006072051204] BSSID[00:0F:BB:09:EC:E9] SSID[CNL-91-0-6-ssid] Details: Radio[2]
