Use the eap command to download and set the certificate from the FTP server as part of the 802.1x EAP-TLS authentication configuration process. You can use the eap command for EAP Proxy mode as well as EAP Pass-through mode. The eap command is accessible from the ap:<serial>:802_1x context of the CLI.
| server | IP address of the FTP server from where the certificate is downloaded. |
| user | User name for accessing the FTP server. |
| dir | The directory where the certificate is stored on the FTP server. |
| file | The file name of the certificate. |
| secret | The password for encrypting the private key. This parameter is optional. |
EWC.extremenetworks.com:ap:0409920201203751 AP:802_1x# eap 192.168.4.88 admin certificates ap3765.pfx abc123
Print
this page
Email this topic
Feedback
