Use the radius-mac-format command to set the MAC address format to be exchanged with the RADIUS server. The radius-mac-format command is accessible from the vnsmode:radius context of the CLI.
After you run the radius-mac-format command, run the apply command to implement the changes.
| 1 | Specifies a MAC address format of XXXXXXXXXXXX for use with the RADIUS server |
| 2 | Specifies a MAC address format of XX:XX:XX:XX:XX:XX for use with the RADIUS server |
| 3 | Specifies a MAC address format of XX-XX-XX-XX-XX-XX for use with the RADIUS server |
| 4 | Specifies a MAC address format of XXXX.XXXX.XXXX for use with the RADIUS server |
| 5 | Specifies a MAC address format of XXXXXX-XXXXXX for use with the RADIUS server |
| 6 | Specifies a MAC address format of XX XX XX XX XX XX for use with the RADIUS server |
| 7 | Specifies a MAC address format of xxxxxxxxxxxx for use with the RADIUS server |
| 8 | Specifies a MAC address format of xx:xx:xx:xx:xx:xx for use with the RADIUS server |
| 9 | Specifies a MAC address format of xx-xx-xx-xx-xx-xx for use with the RADIUS server |
| 10 | Specifies a MAC address format of xxxx.xxxx.xxxx for use with the RADIUS server |
| 11 | Specifies a MAC address format of xxxxxx-xxxxxx for use with the RADIUS server |
| 12 | Specifies a MAC address format of xx xx xx xx xx xx for use with the RADIUS server |
The following example sets the RADIUS MAC address format to XX:XX:XX:XX:XX:XX:
EWC.extremenetworks.com:vnsmode:radius# radius-mac-format 2
