Use the secure-tunnel-control command to enable or disable the encryption of control traffic between APs on this site and their controllers. The secure-tunnel-control command is accessible from the site:<named-site> context.
| enable | disable | Enables or disables secure tunnels between APs on this site and controllers. |
The secure-tunnel command must be enabled before the secure-tunnel-control command can be run.
The following example enables secure tunnels between APs and controllers on site1:
EWC.extremenetworks.com:site:site1# secure-tunnel enable EWC.extremenetworks.com:site:site1# secure-tunnel-control enable
Print
                        this page
Email this topic
Feedback
