Use the range command to configure the DHCP pool of addresses. The range command is available from the topology:<named-topology>:l3:dhcp context of the CLI for b@ac, physical, and routed topologies. This command is visible only when mode is set to local. See mode.
After you run the range command, run the apply command to implement the changes.
| A.B.C.D | Specifies the first IP address in the IP address range. |
| A.B.C.D | Specifies the last IP address in the IP address range. |
The following example defines the DHCP range of IP addresses:
EWC.extremenetworks.com:topology:routed2:l3:dhcp# mode local EWC.extremenetworks.com:topology:routed2:l3:dhcp# range 192.168.1.30 192.168.1.54 EWC.extremenetworks.com:topology:routed2:l3:dhcp# apply
Print
this page
Email this topic
Feedback
