lbs-status
Use the lbs-status command to enable or disable the collection of location-based (AeroScout, Centrak, or Ekahau) tags for any AP. The lbs-status command is accessible from the ap:<serial> and all ap:defaults contexts of the CLI.
lbs-status enable | disable
Parameters
enable Enables the collection of location-based tags for the APs.
disable Disables the collection of location-based tags for the APs.
The following example enables the collection of AeroScout, Centrak, or Ekahau tags for the 802.11n APs:
EWC.extremenetworks.com:ap:defaults:ap3935FCC# lbs-status enable
