Use the wlan-foreign-ap command to enable the application of default WLAN assignments to foreign APs. The wlans-list command is accessible from the ap:defaults: context of the CLI.
| enable | Specifies that default WLAN assignments are applied to foreign APs. |
| disable | Specifies that default WLAN assignments are not applied to foreign APs. |
The following example enables the application of default WLAN assignments to foreign APs:
EWC.extremenetworks.com:ap:defaults:# wlan-foreign-ap enable
Print
this page
Email this topic
Feedback
