Use the rightantenna-radio2 command to select an antenna supported by the Wireless AP. This command is accessible from the <serial> context of the CLI if the AP supports configuration of a right radio2 antenna. For AP models that support the Professional Install feature, rightantenna-radio2 is accessible from the ap:<serial>:professional_antenna# context. Enter the command without arguments to list the available antenna models.
The antenna commands available are dependent on the AP type.
antenna_model | Model name of an antenna supported by the Wireless AP. |
This example lists the valid antenna models that can be entered with this command, then executes the command with an appropriate model number:
EWC.extremenetworks.com:ap:0500010032150135# rightantenna-radio2 Usage: rightantenna-radio2 <antenna_model> antenna_model: <list of valid antenna models> No Antenna WS-AO-2S03360 G 3.5 dBi Omni EWC.extremenetworks.com:ap:0500010032150135# rightantenna-radio2 WS-AO-2S03360 G 3.5 dBi Omni
This example removes a configured right radio2 antenna:
EWC.extremenetworks.com:ap:0500010032150135# rightantenna-radio2 No Antenna
