Use the publish-ap command to enable or disable SNMP publishing of the access point as an interface to the Wireless Appliance.
| enable | disable | Enables or disables publishing of the access point as an interface to the controller. |
The following example enables SNMP publishing:
EWC.extremenetworks.com:snmp# publish-ap enable
If you attempt to enable SNMP publish when LLDP is enabled on one or more APs, you will get the following warning:
WARNING: LLDP is enabled for some Wireless APs. Would you like to continue? (C) Cancel (P) Proceed (O) Disable LLDP and proceed
Type one of the following:
Print
this page
Email this topic
Feedback
