Use the turbo-voice command to enable or disable Turbo Voice optimization. The turbo-voice command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the turbo-voice command, run the apply command to implement the changes.
enable | disable | Enables or disables Turbo Voice optimization on the WLANS. |
This command is only active when either the wmm, 802.11e, or legacy commands have been enabled.
The following example enables Turbo Voice on the CNL-7-CP WLANS:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# turbo-voice enable EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# show turbo-voice Turbo voice: enable
