n_addba_support
Use the n_addba_support command to enable the ADDBA support. Use the no command to disable the feature. The n_addba_support command is accessible from all radio contexts of the CLI.
n_addba_support
no n_addba_support
Parameters
None
The following example enables the ADDBA support:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio2# n_addba_support
