The ospfinterface command moves you to the context ip:ospf:ospfinterface, which contains commands to configure Open Shortest Path First (OSPF) protocol options for a port of the Wireless Appliance. The ospfinterface command supports the specifying of an esaN interface, where N is a number from 0 - 3.
The ospfinterface command is accessible from within the ip:ospf context. If the ospfinterface command does not appear on the ip:ospf context command list, you must use the status command to enable OSPF.
The following commands are available in the ip:ospf:ospfinterface context.
Print
this page
Email this topic
Feedback
