Use the sync-config command to enable or disable synchronization of the configuration elements.
| enable | Enable synchronization of the configuration elements. |
| disable | Disable synchronization of the configuration elements. |
The following example enables the synchronization of the configuration elements:
EWC.extremenetworks.com:availability# sync-config enable
Print
                        this page
Email this topic
Feedback
