Use the lacp command to enable or disable LAGs on an AP. The lacp command is accessible from the ap:<serial> context of the CLI.
| enable | Enables the LACP LAG feature on the AP3825i, AP3825e, and the AP3865e. |
| disable | Disables the LACP LAG feature on the AP3825i, AP3825e, and the AP3865e. |
The following example enables LAGs on AP ap:1111111111113825:
EWC.extremenetworks.com:ap:1111111111113825# lacp
Print
this page
Email this topic
Feedback
