Use the foreign-gateway command to configure the remote Wireless Appliance in a paired controller configuration. The foreign-gateway command is available from the topology:<named-topology>:l3:dhcp context of the CLI for routed topologies. This command is visible only when mode is set to local. See mode.
| A.B.C.D | Specifies the IP address of the remote Wireless Appliance. |
| none | Clears the IP address of the remote Wireless Appliance. |
The following example clears the IP address of the remote Wireless Appliance:
EWC.extremenetworks.com:topology:routed1:l3:dhcp# mode local EWC.extremenetworks.com:topology:routed1:l3:dhcp# foreign-gateway none
Print
this page
Email this topic
Feedback
