Use the status command to enable or disable OSPF advertising on the port.
| enable | Indicates that OSPF advertising will be enabled |
| disable | Indicates that OSPF advertising will be disabled |
The following example enables OSPF advertising on the port:
EWC.extremenetworks.com:ip:ospf:ospfinterface:top1# status enable
Print
this page
Email this topic
Feedback
