Use the status command to enable or disable the Open Shortest Path First (OSPF) protocol on the Wireless Appliance.
| enable | Indicates that the OSPF will be enabled |
| disable | Indicates that the OSPF will be disabled |
The following example enables OSPF on the Wireless Appliance
EWC.extremenetworks.com:ip:ospf# status enable
Print
this page
Email this topic
Feedback
