Use the ssid command to specify the Service Set Identifier (SSID) for the WLAN service being configured. The ssid command is accessible from the wlan:<WLAN-service-name> context of the CLI.
After you run the ssid command, run the apply command to implement the changes.
| string | Specifies a string for the SSID. The SSID string can range in length from 1 to 32 characters. |
The following example specifies and then displays the SSID:
EWC.extremenetworks.com:wlans:test# ssid testssid EWC.extremenetworks.com:wlans:test# apply EWC.extremenetworks.com:wlans:test# show ssid SSID: testssid
Print
this page
Email this topic
Feedback
