Use the apply command from the provider-config context to apply changes to the provider-config context.
There are no parameters.
Once the provider has been configured, use apply to apply the changes.
EWC.extremenetworks.com:wlans:hs:hotspot# provider-config https://Enetworks.com
EWC.extremenetworks.com:wlans:hs:hotspot# hs-provider-methods oma, soap
EWC.extremenetworks.com:wlans:hs:hotspot# hs-provider-provider-frn1 ENetworks
EWC.extremenetworks.com:wlans:hs:hotspot# hs-provider-icon bird.png
EWC.extremenetworks.com:wlans:hs:hotspot# apply
Print
this page
Email this topic
Feedback
