Use the vlan-policy command to map a VLAN ID to a policy.
After you run the vlan-policy command, run the apply command to implement the changes.
| add | update | Adds or updates the mapping of the specified vlan-id to the specified policy. |
| remove | Removes the vlan-id mapping from the policy. |
| vlan-id | Specifies a VLAN to map to or remove from the specified policy. |
| policy name | Specifies a policy to which a VLAN is mapped. |
The following example updates the VLAN mapping (vlan-id 102) to the test2 policy:
EWC.extremenetworks.com:vnsmode:adminctr# vlan-policy update 102 test2
Print
this page
Email this topic
Feedback
