Use the redirection-url-list command to create, delete, or modify a redirection URL list. The redirection-url-list command is accessible from within the root: vnsmode:redirection_url context.
| add | Adds a URL. |
| delete | Deletes a URL. |
| redirection url | Identifies the redirection URL |
| sequence id | Identifies the sequence of the URL. |
Before you can configure a redirection URL list, enable policy rule-based redirection using the rule-redirect command. You can add or delete more than one URL at a time.
The URL list can contain up to 255 proper URLs, consisting of Fully-Qualified Domain Name (FQDN) addresses and IPV4 addresses. Duplicate entries are not permitted, and you must ensure that network traffic is accessible to the required IP addresses. The name of the WLAN Service that these entries are created for is displayed on the user interface and on the command line interface. SNMP also displays the URLs when queried through the Policy Profile MIB.
EWC.extremenetworks.com:vnsmode:redirection-url# redirection-url-list add https: //testing.com/login.htm EWC.extremenetworks.com:vnsmode:redirection-url# show SeqId URL 1 https://testing.com/login.htm
